Betsy the Worktruck
saburai
@IDIBRONCO took me a minute to find but these are Harbor Freight special gauges. Included in them is the engine temp gauge that apparently loves leaving its tip inside an engine and the OPG reads low. Looks like I’ll be purchasing a new set when I have the time.
Imho one of the things that it's not worth it to skimp on is quality gauges.
saburai
I’ll be making a bracket for beneath the wheel and then getting some nice ones. What brand do you recommend?
When I was doing VW and Porsche cars I primarily used VDO. In my current truck I have Auto Meter I'm pretty happy with them as far as the accuracy goes. However they tend to fog up a bit too much for what is supposed to be a quality gauge. I believe that isapro is also a high-quality gauge and I'm sure that there are some other quality manufacturers out there, however I only have experience with the ones listed above.
Scotty4
Does this speedometer drive gear look okay? PO left me a parts box that I’ve been going through and found a new Red gear and Green drive gear. Seems a hassle to do the drive gear.
Nope. It's bad. All of the teeth should be pointed looking like the top two. I can't remember if you said what transfer case you have. Mine are (the one in the truck and an extra in the garage) both BW1345's. I haven't been able to keep a drive gear in one no matter what I do. They only seem to last for 10,000-15,000 miles. A transmission shop that I actually trust told me that they did seem to have issues with this. It was suggested to run an extra 1/2 quart of ATF in the transfer case. I tried that the last time and it didn't help. I've seen others on here say that they haven't had any issues with the drive gears in their BW1345. I certainly won't call anyone who says this a liar, I can only give my experience. I finally gave up and started running a digital universal GPS fed speedometer. I have no idea on miles, but at least I can keep track of my speed.
Where would the 1345 # be at on the case?
The 13-45 is cast into the back side of the transfer case. The numbers aren't very large so they may be hard to see if there's some crud build up on the back side of the transfer case. I want to say that it's in the area of the drain/fill plugs off slightly to the driver's side. Remember that my above post is only my experience and not gospel by any means.
Scotty4
Pulled heater blower today because I’m bothered by the rattling. Picking up a new one here shortly, this one has seen better days.
Scotty4
Installed new Crown Vic Blower tonight. Needed to use a Dremel to remove ~1/4” of material to match the OD. Used some self tapping screws and some glue on the gasket before installing. Plenty of dialectic grease on the plug and she now blows better than ever. P/N was PM9298 and was branded by VDO. Took about 20 minutes.
saburai
Is the Crown Vic unit a big upgrade? Curious as to why you just didn't do a new stock replacement.
Scotty4
The crown Vic one looks to have a better style bearing than stock and the larger fan seems to move more air from what I can tell.
Maybe a new stock replacement would be nice but with 20 minutes work this dropped right in. Was cheaper for this whole assembly than for the replacement stock, motorcraft motor.
Cv axle
