Best way to tie truck to trailer
laserjock
Almost there...
^^^ This. The tail will wag the dog and that is not a good feeling.
I have short chains and binders at hand typically for all four corners. I have been known to chain the front solid and then tighten it all with 10k lb ratchet straps to the rear housing either with the do-dads snicklass showed or use chain for the wrap around bits so that it doesn't cut the straps. Basically using the ratchet strap like a chain binder.
Lance
