Wanted to see if the often stated 300 plus degrees at 15 psi was true for the banks wastegated turbo.
So I purchased a thermocoupler/meter and placed one thermocoupler in the intake hat.
This is what I found so far.
temperature outside was 40
boost psi temp F calculated density lbs per cubic foot
0 40 .079 for reference this is what a n/a engine should see same cold air inlet.
5 140 .089
10 189 .103
15 206 .121
Biggest jump in density is from 10 to 15 psi.
I will update when warmer weather arrive to see how inlet temps reflect outlet.
5 140 .089
10 189 .103
15 206 .121
