Bad Jasper engine.
idiabuse
Princeton Fl
Ok I may be wrong, Usually off the top of my head I get it right, I must be getting old. I have seen plenty switched so I may have been mistaken, 351W didn't use the 7/8 combo firing order now that I remember, so thanks for the correction.
I still going to check on it cause them cobb webs are getting thick need to get the broom.
Javier
DeepRoots
Tug Engineer
Douglas, Georgia
didn't mean to cause any confusion, I just wanted to make sure the firing order was noted.
easiest way is to just go and swap the plug wires to the other firing order and crank it up. It'll be obvious if it's better or worse :p
Bradz
