LCAM-01XA
Well crap, the guy that had a "hydroboost" set for sale doesn't know the differance between a vaccuum booster and a hydrobooster.
Since it was coming off a 96 ram 2500 cummins truck, I thought it would be a hydroboost set-up, my 97 and 98 rams both had hydroboost. But this 96 assembly was a vaccuum booster. So there goes my super find on a hydroboost for the big green slimer. Guess I'll keep searching, everywhere else I look is about $250 for a set up off a superduty or big truck. I like the sound of $50 much better, so I'll keep searching.
Chevy boosters ran me like $17 from the U-Pull-It two years ago, may be up to $25 now. Remanufactured master cylinder of your choice is about $20-25, bit more for a new one. I know for sure the '80s Chevy hydroboost units can use Superduty (old F450) pressure lines as that's just what I'm running in my truck right now. Additionally, Astro vans run hydroboost too, only their pedal rods are much shorter than what fullsize Chevy trucks use - crawl up under your dashboard when you get the chance and measure up the distance between the firewall and the pin of the brake pedal where the booster rods attaches too, and I can probably recommend you what GM hydroboost to get.
