So now that all my woes appear to be taken care of except my occasional power steering drip in the other thread, I'm on to something else less significant but that makes leaving anything in the truck stressing. The back drivers side power lock does not work, and furthermore the little black pushing rod to manually lock and unlock is totally gone from the metal piece under the door frame.
I managed to spray a boatload of wd40 in there and that did nothing. Doesn't act like it is getting power of the little motor is shot. I was able to lock the door by putting a flat head screw driver in the door hole claw retaining.. I have no idea what it is called. Place the door shuts on to the rod you have to adjust when your doors start wobbling down the road. It looks like a tiny pry bar in there and if I push up on it my door will stay shut, and to open it I have to roll the window down and take same screw driver and put it through top of window hole and then pry up on the rod that would have had the black push button to manually lock and unlock the doors.
Question is, if I wanted to test whether I'm just not getting power to that actuator, could I just hook a test light onto the two wires going into said back door and press the button and see if it lights up or not when I press it? Not sure how to test it. Wouldn't even care if it didn't work if the manual button existed out of the top of the door. Even weirder it stays locked even when pulling be handle inside when locked by screwdriver method, although maybe that's some sort of child protect feature and the back seat doesn't open when you pull the handle.
Thoughts? For now I'm just gonna manually lock it via screwdriver so I can go shopping and leave stuff in it for fear of being stolen. I work near a bad part of Pittsburgh and I'd also rather not find my stereo missing someday either.
