Progress, items to replace?
1) Axle out - DONE
2) Hub off - DONE
3) Outside wheel bearing - DONE
4) Axle seal Off - Done
5) Need outer bearing - Yes, see pic
6) Need inner bearing - Maybe
7) Gouge in hub, above where bearings sit, see picture. The metal piece from the outer bearing was near the axle seal, maybe it caused the gouge?
This is the piece of metal that was between the axle seal and the inner wheel bearing
This is where I think it came from, outer bearing:
Given these pictures (everything else is smooth):
I know I need to replace the outer bearing
1) Do I need to replace the inner bearing also?
2) Do I need to replace the hub or can i smooth that gouge just a bit?
Thanks,
David
