auto on 94
gwhammy
mo
My brother bought a 94 auto unmolested truck. It runs good but after he rode in my truck he would like a little more power. What needs to be done to the auto to stand up to somewhere between 250 to maybe 300 horse. He pulls light loads but mostly just for transportation. Thanks
Mr. Fix it
Brighton, MI
If your brother wants to try a get every last mile out of the tranny, then I would go mild. Sounds like he does not even need the 300 hp. My 97 is pretty much stock (plate moved a little forward), and it pulls my 6500 lb 5th wheel well. It ain't gonna win any races when empty, but will keep up with the big block chevys when towing. I'm trying to get every last mile out my tranny, when it goes, then I'll do the DTT or ATS thing. Once thats in place, then it's bomb big time.
I would start with a complete flush and filter change of the tranny, consider supplimental cooling of the tranny, and maybe check out the tranny pressures at all the ports per DTT's website (they have pretty good instructions on how to). The pressure readings will tell you the state the tranny is in, and MAYBE you can up the pressure A LITTLE BIT. Of course, all of the usual checks like overflow valve, fuel lines, filters, linkage, etc. Make sure everything is right before going on.
As far as bombing goes, (just my opinion) a #11 plate, free flowing exhaust (5" with or without muffler), boost elbow, free flowing air cleaner (BHAF), would be a nice addition to the way the truck runs without going crazy. When the tranny goes, get a good one, then the sky is the limit. When the tranny is upgraded, the only thing he will have to redo is the plate, and no problems trading in or selling a number 11. Then go with a new plate, turbo, bigger injectors, manifold, etc. I did not mention injectors in initial bombing cause they can get pricey and for a stock tranny, it's not worth it to change them, just to go bigger later when the tranny can hold more power (bigger injectors).
Hope this helps a little, Kevin
gwhammy
mo
His is the first auto I have rode in. When you mash it seems like the torque converter just sucks up all the power as it is excellerating. Tranny does shift real firm so it could have been worked on before he got it. I know he doesn't need all the extra hp. but it's so easy to get and is nice when you want it. Wonder if just a torque converter would work for him and check pressures?
blackeye
US of A
The converter is only around 70% efficent. I could not afford a D.T.T. setup sooooo got a master rebuild kit from Transtar, Trans-go shift kit and ordered a custom 90% converter from Edge racing converters. Total cost was 973.78. Setup works excellent for my truck with mild bombs.
Alleycat
