67-7THREE
hi, im doing a 7.3l idi non turbo swap into a 67 f100 (build thread coming soon) and i recently picked up a complete turbo kit from the junkyard. picked it up for $200 along with a isspro egt gauge, but anyways, it appears to be a 088 kit?
i tried to pull everything off that i needed, but i wanna make sure.
i got: crossover pipe, y pipe, down pipe, turbo, oil feed line, air box, cdr, intake tubing, turbo mount where the cdr use to be, snail hat and the cdr hose that went to the valve cover, but it broke.. and also grabbed all nuts, bolts and downpipe bracket
anything im missing?
and where can i get a new cdr hose?
i read i have to punch a hole in intake gasket/pan where the cdr use to be for oil drain? and is there a grommet that i need that goes there?
anything else i should know?
thanks!
also, i have A code injectors, are B code any better? thats what was on the motor with the ATS kit.
thanks!
