Ok You know much more about engine oil than I do, You mean that even a half synthetic is still no good right?
I'm not using motorcraft on the 5.9l ctd I thought about delo400 (sp?) but You guys are saying is no good either right.
So the only way to go would be something like amsoil or the oil with the sync in it?
how about using some lucas with the regular oil, will this oil stabilizer make up for the lack of sync?
As far as motorcraft or any other dino oils having synthetic in them, if there was a significant enough amount to make a difference, theyy would be labeling them as a synthetic blend,( which aren't half bad options for those wanting more protection, but happen to have an oil burner and don't want to break the bank) but since they are not labeled as a blend, it's pretty safe to conclude that at most there is a synthetic additive, and not enough to make the kind of difference to compensate for the lack of zinc in dry run situations.
Flip side of this is that with the roller cams in these engines, and the fact thet by now, most have had head work done and are running the umbrella seals on the exhaust valvesso the guides do run dry , there really isn't any place in the engine that is prone to the kind of dry run situation that zinc would make a difference on, unless you are really winding the thing out hard, I suppose there's always a possibility, which is why a high end synthetc is the safest bet, since they have a habit of hanging on better in the first place, and one like the Amsoil 15w40 diesel and marine was kept to the old spec for older engines so it has the best of all worlds for older engines ( and the older spec synthetics have zinc in them as well ), their newer lighter diesel oils are set to the new spec, but being what they are, any of the high end synthetics are going to protect better than a dino oil with zinc, it just becomes a question of how great is great. You are basically comparing apples to oranges trying to compare any high end synthetic to any dino oil.
For normal running, I wouldn't be concerned about running Delo . with the lubrication systems in these things, it just shouldn't be a problem. even the dino oil that's out now is a far cry from what was spece'd for the engine when it was built. it's just a matter of how much better protection would you like than that.
