LCAM-01XA
If you do, please confirm U-joint size at axle yoke, 1350 or big-cap 1330? You can measure diameter of caps on the driveshaft side of this joint, 1.188 is 1350 and 1.062 is 1330. Measuring caps that go into the axle yoke is not ideal because Ford's 1330 joints use special larger caps there (1.125" dia) and difference between a 1330 and a 1350 joint will not be as apparent. Thanks!
