Patience my a$$!!!!
Well, three 3/32" allens and this:
Realize, I live 12 miles from the nearest tool place, and if they don't have it, trekking off into the circle of hide-n-go-seek.
I may have had better luck with a paper clip!!
Anyhow, the above photo is the result of the "final" set screw "breaking" loose! First one almost broke it, second one did, but both sets finally broke lose, used one of my bent ones to tighten them back in.....sheeesh!
Here's the end result:
The new is a Uhaul.
Interesting thing, when I got the old IP off, it was hard to turn the pump, then I twisted it backwards/forwards/back/for/ and it started moving freely and spun like it wanted to pump again. Sumpthin gave up inside. I drained the input side and squirted a little diesel up in there to free up dirt in the IP filter, nothing came out.... weird.
There is a throttle assembly difference though. Not too worried, but may have to duct tape it all together....eeerr... modify it a little.
Injectors Typ4 sent me will go in first. Pulled the old ones, #8 had a lot of rust along the injector body, water obviously sat on the valve cover too, slow leak/weep. This truck is a low miles sitter, so in any water accumulation, it had time to weep.
Injectors #'s 1,3,5,7 all were wet when I pulled, with bubbles leaking out of the pintle and copper washer area.. #'s 2,4,6,8 were all dry. All had typical soot on the tip, but the tips actually looked pretty sharp and seated. No carbon beyond the tips on any injector, all coppers looked brand new too.
All the injectors were made by CAV in England. The only thing that made sense to codes were pass side all had "DH" and the drivers side had "CH". The only thing that made them different or indicated a letter code. It was stamped on the body under the 1" installation nut, along with the part number. Nothing above. Hadn't seen that code series before in discussions. BB's will go in tonight.
Is there a torque value for the injectors? Or snug and a quarter/ half turn? Do we use anti-seize at the block on these injectors?
Thanks for the help fellas!
These things really are pretty easy to work on... better than being wedged between hot engines any day!
