Ataylor
Hi everyone,
I finally got my truck running and timed. Many thanks to all that have responded to my questions during this overhaul. I'm very greatful to have found such a great source of info on these trucks.
I'm currently having a problem with the Airdog fuel pump/filter getting very hot while running. It has only about 2 hours of run time. I have replaced everything on the fuel system. New in bed fuel tank with 30 galllons of fresh fuel and additive(old tanks removed), large prefilter before the airdog, all new fuel lines to and from the engine and tank, new Baby Moose IP, new BB injectors, new return caps and lines.
I noticed tonight that when I went to start the truck that I didn't remember hearing the Airdog start pumping like normal before I cranked the engine. Truck started without needing to glow the plugs and I ran it for about 10 minutes. While running I went under the truck and felt the pump to see if I could feel it running and it was really hot and did not seem to be spinning. It was hard to tell with the engine running and I know these engines will run without the lift pump functioning properly.
I shut the truck off, and turned the ignition to the run positition and I heard the pump start and run. I could hear it recycling fuel back into the tank, but again when I went under the truck the pump was very hot to the touch. The relay for the pump which is in the engine compartment was also warm to the touch. I used the complete wiring harness and relay that came with the Airdog kit and it is wired directly to the battery per their instructions. When checking for power to the Airdog it has full battery voltage.
When I first tried to fire the engine the first time since the fuel system overhaul, the Airdog wouldn't spin. I called Airdog and they said to remove the pump take it apart and check that the rotor was free to spin with the cover removed. They said that because the pump had sat so long that the prelube could have gummed it up. I took it apart and it was free to spin. Reassembled with a little white grease per their instructions. It has been working everytime I turn the key to run, but now it is getting hot. To be honest, I have not felt the pump before tonight, so maybe it was running hot this whole time, but I didn't suspect anything was wrong because I could hear it pumping fuel whenever I turned the key.
So my question is, does anyone think that the pump is getting hot because it is having to suck through the prefilter? Too much restriction?
The prefilter is a large Napa filter head and large filter with -8 AN lines running from the tank to the prefilter and to the Airdog. The Airdog has it's own water separator and filter, but I thought the prefilter was a good idea. The fuel line from the tank including the prefilter is only about 4 feet before the Airdog and it siphon fed itself so I didn't even need to fill the filters to prime before I started the truck for the first time.
I would hate to have to make new AN fuel lines to take the prefilter out of the loop. And I'm not looking forward to removing the Airdog to take it apart again now that it is full of fuel, but it looks like thats what I'm going to have to do. I have a Airdog on another truck and it has been very reliable, but it doesn't have a prefilter either.
Thanks for any advice anyone can offer.
Sorry for the crappy pictures, it was dark.
Archie
Archie
