add a turbo at 200k?
redneckaggie
rebel w/o a cause
angleton/stephenville tx
studs are stronger than the stock headbolts and yes in almost any situation if you remove a part that is sealed by a gasket then you must replace the gasket.
Diesel JD
Gainesville, FL
Well your dad being an aircraft mechanic, hopefully his acceptance of failure is pretty low... consider the consequences! If you blow a head gasket, you probably won't even hurt "the family truck" but you will be in for a LONG weekend to fix it. That's all. You want to buy ARP head studs if you stud it they are cheaper than a factory set of new head bolts. Get them from your local ARP shop or Summit Racing's website.
dukedrummer89
IL
Put on the turbo and Run it!
ditto... mine prob has well over 200k if not 250k plus... i slaped an ats on mine and have been running the snot out it for a couple months now.... ive pulled 10k with it, i pull 6k alot, take the truck wheelin, hammer on it on the street, and bounce it off the rev limiter... still runs fineLOL
RangerDanger
