96 F250 no turn signals,no brake lights,no reverse lights HELP
NHBaler
On my 96 F250 with a 351 I have no turn signals,no brake light,no backup lights,no four flashers this happened awhile back and I changed out the turn signal assembly and it fixed it and now it is out again so I got another switch from another parts store and it hasnt fixed it and the wipers do work and the headlights and park lights work. Is there some other breaker that might be bad? I have checked all the fuses and they all have fire in them. Any help would be appreciated.
NHBaler
OK thanks that maybe where my problem is I will look around there and see what I can find
NHBaler
Well found my problem the 4 way switch was on and that takes all the juice so nothing else will work but the 4 way flashers arent working like a bad flasher or something so I didnt know the switch was on any way I turned them off and the other lights started working easy fix,but thanks for all the help and hopefully one day this might help someone with the same problem
lewisstevey7
