Hey guys,
Trying to get the parts to fix this oil leak without having to take it apart first. My preference would be to repair the factory line, but I can live with retrofitting a braided stainless line into place.
After searching through a bunch of different posts I haven't found anything recent regarding availability of the rubber packing sleeves (aka olives) that are used on the oil feed line for the turbo. Are these still available? Any easy sources for them?
If not, is there an oil line kit available (ebay level) that one of you has used? I see plenty of them available for ~$20, but I don't want to waste my time or money on something that's poor quality or won't bolt on.
Otherwise, if I'm going to piece this together from Summit, what will I need? I understand that the fitting on the block is a 1/4" NPT (it is a '94), so, if I were to put my own line together I would need that. What size fitting goes into the factory distribution block sitting on top of the turbo? Is 6 AN the appropriate size?
Thanks, John
Thanks, John
