94 6.5 NA problems...
mohavewolfpup
Diesel Wolf Puppy
Las Vegas Nevada
Here is the best I can do. Looks like this. Oil pressure switch is on the far left when you take the cover off, back of the block.
tanman_2006
Seiling Oklahoma
That oil sensor runs your lift pump, I wouldnt completely ditch it.
Has the engine ever been swapped out? A couple possibilities is it has a low vol/low press pump NA non squirter block. If it has a newer block then it SHOULD have high volume/low pressure pump iirc. The oil bypass valve could also be stuck and bypassing all the oil.
mohavewolfpup
Diesel Wolf Puppy
Las Vegas Nevada
It was replaced at some point with a block date coded 2000. That's all I've been told at this point
tanman_2006
Seiling Oklahoma
That block will have high flow piston squirters and needs a high volume pump. High pressure and high volume for a turbo'd application.
