All the replacement mechanical lift pumps have a different shaped lever. The original pumps had a “dogleg” shaped arm. The new replacements have an almost straight arm. This is why you have to make sure to get the new pumps arm under the cam lobe. There are several threads about this, and some with pictures. The only way you are going to get one that looks like the original one is if you can find a NOS sitting on a shelf.
