BigRigTech
Diesel junky
I swapped the old IP off the 6.9 tonight for the reman unit I removed from the 7.3 in my 94 E350 "junkyard shed".....It's supposed to be 1-2yrs old with low miles. The swap went relatively easy with some interesting findings and results. I hope the pic's of the timing marks can been made out.
Here;s the soon to be installed reman pump.
Here was the static timing marks on the old pump before I took it off....It was retarded the width of a dime!!!!.....Hence my lazy 6.9.
Here is where the new pump is timed now.
As for results, it started easily, smoke was almost nil - nothing like it used to be and it sounds MUCH better....If I wasn't standing in front of the 92 I would swear I was listening to my 91 running like a swiss clock.....I think the low power issue is going to be handled but as I expected to find - the injectors are toast. #3 is sticking open thus letting combustion back into the injector - it boiled the fuel around the injector body when I ran the engine for 2 minutes and #5 has compression coming up around it (bubbles visable in the fuel spilled from bleeding the lines)....The rest seemed ok as there was no visuable issues....I also now have a slight ticking sound audible that wasn't there before, but I'm not too concerned about that until I swap in new injectors in the next week or so as it could be one of them....I'm on the right track to more power in my 92, can't wait to get it done and hauling heavy.
