6.9 IDI ARP Headstud ?
Hydro-idi
Lodi, California
Well it looks like the saga continues with my truck. I took it for a drive yesterday and noticed bubbles coming from overflow tank while engine is running. Looks like I will be pulling heads off this engine AGAIN :rolleyes:.
My question is, I have re-used these ARP headstuds about 5x already and not sure how many more times I can use them before they start fatiguing. Maybe they have already been stretched a few too many times which is why engine had a headgasket failure :dunno?
Any help would be appreciated. Thanks guys
something in this area is infecting our engines, lets just call it the "Jerry Brown Syndrome"!
I would try re-torqueing the studs first.
Hydro-idi
Lodi, California
If your torque wrench is properly calibrated, and your having repetitive head gasket failures, I would question the flatness of the block or head. ARP studs don't stretch that I've ever heard.
Mels's comments about ARP studs is so very true. They can be reused many times without issues. Something about the cleanliness of the head to block surfaces is suspect or as Mel stated. something might be warped. Sadly a straight edge is the best way to "find the warp".
Hydro-idi
Lodi, California
Thanks for the responses Mel & Gary. I've done this job so many times I did make double sure that everything was surgically clean & both the block & head decks were checked when I brought them to machine shop earlier this year.
I just pressure tested the cooling system and it does not hold pressure. After about 15 minutes, it bled down a few psi :/.
I have my spare "ready to run" crate motor sitting in garage and might swap them out. I was thinking about selling it until now.
This engine definitely has some bad juju on it, as we all know with the previous thread I posted earlier this year.
Tyler9828
Staff online
