6.5 Detroit 1994 GMC Sierra runs smooth then gets a little rough then smoothes out again
Drak101
Las Vegas
Hi there guys I finally got the truck goin, it runs good, but then it will run a bit rough acts like it wants to die. Has had some bad fuel in it for some time I filled it up and added some cleaner could it be a low pressure lift pump? Still runnin the stock pump. Thank you
Drak, you are in the wrong forum section, this is the Ford IDI Diesel Forum.
Great you got her going, don`t have a clue about the General Motor truck engines. Sounds maybe like air in the fuel system.
If it sat with old/bad fuel in it for a while, your injector pump may still be sticky inside. You may have to drive the truck for a while in order to free the pump up again. I said that because it sounds like you haven't driven it very much since you put the fresh fuel and cleaner in the tank.
Alleycat
