I would suggest that if you are seriously going to do this, that you get your hands on a parts vehicle. You will need Cross member, drive shaft, Clutch kit and master, flywheel, lines, pedal etc. These items along with some smaller items are much easier to grab off a Donner then to try and find individually. Not to mention, when you are three quarters of the way through the job and you go OH **** I forgot about this and you are stalled it sucks. BTW I am not suggesting using a used clutch, but it is good to have for Mock up and to make sure you are getting the proper new parts.
