why not just buy a rolled 4 in 90 and have it stretched at an exhaust shop so it will slip over the over the axle piece and that can be your exit pipe. I dont see why people want pre fabbed kits much cheaper and easier to get what you want when you build it your self. do you have an exhaust shop, or even better a big rig shop around you, talk to them and they can likely hook you up with whatever you want.
I know I just bought a stick of 4 in aluminized exhaust pipe from the local exhaust shop and the guy charged me like 30 bucks to bend up the over the axle piece and I went home and reduced the 4 in to 3 in on one end(had a short piece of three in that slipped over the od of the stock exhaust perfect.) and then just cut a straight section long enough to go from tranny crossmember to over the axle run and then another straight piece that went from over axle out. mine exits at a 45, you have material to weld stainless exhaust because a normal mig or short arc wont do it?
