ericwade381
guys just want to make sure I have this correct. I have read the yellow wire can get taking to the back of the alternator with the power plug with the main power wire or ran to fender solinoid ? So basically the only wire that is good from the regulator is the green wire cut that off as close as you can get to the plug splice the green wire from the new alternator into the old green wire and basically that is it?
