2005 H&H Enclosed Race Trailer
morepower02
minnesota
I am selling my hauler. here are the specs: Model CL 101x24 I have added Two work benches, Insulated the ceiling, added full lighting and recepticles also a wall mounted propane furnace. I also have the ladder that mounts on the front to get to the observation roof. I have not mounted it yet. This trailer is 6 months old. Here are the standard features: 100% tubular steel chassis including frame, walls, ceiling supports
Smooth, rivetless 040 aluminum body system
NitroCoat covered tongue and tail bulkhead
Full digital L.E.D. lighting system including body markers and taillights
Custom aluminum extruded body trim
.090 aluminum fenders
Two 4,995lb rubber torsion axles with EZ lube 8-bolt pattern hubs for a 9,990lb GVWR
4-wheel electric brake system and battery breakaway
CCA treated ¾ laminate flooring on 16 crossmember spacings
7mm Mahogany hardwood laminate wood interior walls
Polar brand brass bushed body hardware, hinges, and door latches
White E coated wheels with trailer radials standard.
36 passenger side access door
24 tall polished aluminum rock guard with trim
Double true rubber door seals
Body fully undercoated
2 5/16 posi-lock coupler, safety chains and 7K drop-leg removable jack
4000lb spring assisted rear ramp gate with transition flap
Polished .040 aluminum front vertical corner trim
Floor-mounted dual E-Track and clips
4' dovetail
Check out hhtrailer.com for the full run down. This trailer sells for 9850 new. I am asking 7899 OBO.
Cv axle
