2000 stroker that was dead finally came to life
NHBaler
Well after a lot of cranking it finally came to life!!!! THANKS for all the help from you guys couldnt have done it with out yalls help! But one more quick question it has a little miss to it especially at idle runs good on hwy acts like a fuel problem,it has been sitting for awhile do you think the fuel is just old? I put a bottle of PFFP in it and see if it cranks and runs better tomorrow. THANKS again!!!!
lindstromjd
Black Sheep
West Des Moines, IA
Run it like you stole it after it warms up. You need to work all the air out of the system. It's a dead-head system so there's no good place for air to go except through the injectors. Only way to ensure that is to give the injectors as much fuel as they can handle for a while.
these engines are a PITA to get fired off when all the oil is out of them.
sucks! but after its all worked out, there awsome!
RustyNail351
