1994CTD electric or macanical fule pump
oHBMQUINN
columbus ohio
Found fule leak drivers side Looks like from a mecanical fule pump on the bottem like the diphram .Anyone else ever have this problem ?
oHBMQUINN
columbus ohio
This is called a transfer pump cummins part# 3936316 leaking at the weep hole located on drivers side on back of block primer pump is attached to pump
2500cummins
Not far enough from Vegas
AFAIK
Very few problems with the stock lift pump on a 12v engine, I think its usually recomended to replace with the stock pump unless you are modified quite a bit, then maybe a high flow electric pump of some kind.
If I'm wrong I'm sure a 12v guy will be along soon to straighten me out :backoff
dented73
