1991 F250 E4OD Super Cab
BDCarrillo
Abilene TX
1992 F250 E4OD Super Cab 2wd
Well, it needs work. #1 cyl exh valve is chuffing, return lines leak, no bed, and tranny makes a weird noise going into gear from neutral.
It'll drive anywhere, just add batteries.
Work done on it:
Steering links
Shocks
Front brakes
Brake master
New torque converter
New tires up front
Shower head fix
Tach sensor
Fuel pump
Diff lube
Coolant flush and filled with peak fleet charge
New coolant hoses
AC refresh (all except compressor)
Interior is in good shape
Too many projects, need to trim down the fleet. First $700 (negotiable) gets it, I'm in Tuscola TX. Clear title in hand.
(Pics will be posted later)
BDCarrillo
Abilene TX
Please pardon my error on the title... I put the wrong year. Sun angle is rough right now... If you want to contact me by cell: 520-26O-OI50
BDCarrillo
Abilene TX
I can knock off transportation costs right now, otherwise I'm booked up on weekends for a while.
Still needs batteries to get going. I only have one spare marine batt to throw at it.
I did have it up on craigslist a while ago... Yes, there is surface rust on the frame where the bed was. I can snap a closeup in a few.
Passenger spring mount area, which is one of the roughest looking spots
WOW!!!! You southerners are spoiled...... That "rough" spot doesn't look too bad to a rust-belt-er..........
Here is a couple quick snaps under my 03......
For being driven year around, in the salt and slurry, it's in really clean shape, for the rust belt.......
Now, to the other side, I have a 91 Jetta that came from Michigan...... if you bang the bumper with your fist, rust will fall onto the driveway........ LOL
Waystro
No Class
South Texas
Still got it?
how bad is it chuffing? More pics text them if it's easier
210-900-7217
Bradz
