dbarilow
over worked
On the market regretfully.
My 89 F-250. 192K miles. Here is what you’ll be getting; Single cab, cloth seats, 2wd, automatic, new IP, new Returns lines, Kens Stage 1 injectors, Properly timed via Mel, 2 gauge pod w/Autometer NV pyro. Glow Plugs Ford beru 2 years old, Batteries AutoZone lifetime 2 yr old, New positive battery cable, New starter, New vacuum pump w/pulley, new glow plug controller, new high pressure hose for power steering, New radiator, New heater core new U-Joints front and back, Headlight mod, new CDR. Also includes diamond plate tool box.
So what’s wrong with it?
Damaged front left bumper quarter panel, got in the way of a moving guard rail.
Rust starting around rear wheel wells
Rust back side of the cab behind door
She runs well and strong, IP has been turned up all the way and shell smoke you out on WOT but no smoke if driven conservatively
What I have but is not installed P-S-T.com poly graphite bushings for the front end includes: upper and lower ball joints, axle pivot bushing, control arm bushings, sway bar bushings.
I'll add pictures later.
P.M. me for questions
