1988 ford f250 7.3 idi 4x4 5 speed
887.3DirtyD
Lancaster,OH
Cal or txt me is best (740)438-8449
Good:
New glow plugs and controller
Radiator and core support
Water pump n fan clutch
Turn signal switch
New Stainless steel pass mirrior
Stanton pressure realieve rad cap
Valve cover gaskets
Air filter
Clutch
Batteries n alternator
Starter
New front axle moog u joints
New hood/doors/96 front clip/ better bed/ new steel on drivers side
sony door speakers n nice kenwood radio
38 gallon rear tank
Newer 1g alt n batteries with new terminals
Newer brakes n last 2 years
Just did an injector return kit
bad:
Needs rear upper shock mount replaced or welded
Rear driveshaft needs a u joint
Power steering pump
When in 4wd it clanks and is noisy espesiay when turning(thinkin hubs?)
Has some other small problems but I still drive it every day
Price-$2800
Trade for a auto 4x4 powerstroke
opusd2
BFE, WI
In the picture with the rear wheels parked on grass and front on the driveway with the photo taken from the front driver's side angle, what size and kind is that tire? Looks pretty tough...
Cv axle
