papastruck
I discovered while farting around underneath the truck the other day a disconcerting amount of Dexron puddled on the skidplate under the xfer case. It looks like it's coming from between the 2 halves. I found a thread concerning resealing by just removing the back half of the case, but after considering that the thing is probably original with 260k miles, it seems like a good time to take advantage of a deal on a 1356. Can I swap outputs on the 2, since the 56 is a slip yoke and the 45 is a bolt-on (or do I have that wrong entirely)? Anyone know what else has to be considered? I swear there are threads on it, but I've got bad search mojo today, apparently, and I can only find bits and pieces.
Thanks in advance.
Thanks in advance.
