Looking to buy a 1-ton flatbed 1991 1/2 4X4 Dodge 12V Cummins from a friend. The engine (intercooled) is stock, 160 hp with 400 ftlb torque. The engine is just getting broken in with only 148K miles on it and runs really good. However the 5 speed transmission seems trashed with lots of sloop in the gear shift, syncros seem worn out. When you pull the selector out of 5th gear into the neutral position, the tranny stays in 5th gear unless you pull the gear shift straight back. All the gears work but you pretty much have to double clutch to shift down. Shifting up seems ok but not real pretty. Is this something common with these transmissions? I think the tranny should be rebuilt. Any ideas? What would be the cost of getting the tranny rebuilt if I pulled it out of the vehicle? Anybody do this out there?
I also want to get more power/torque out of this engine. Anyone know how much more I can get WITHOUT making major changes (like turbo, intercooler, fuel pump)? I plan on installing the standard pyrometer and boost gage. Is 1200 degrees F the max for exhaust temperature? I've heard this model doesn't have a waste gate but I don't know for sure as I didn't notice if it had one or not. Should I just start tweeking the pump adjust until it starts smoking?
Anyway, thanks from your help.
swade (lots of diesel stuff, mostly NA)
