I found this in the brake mastercylinder section. Item number 270146017792. It has about 6 days left and 1 bid of $1.00 with no reserve....
There is several ways of swaping over. The cheapest way is to get (buy or steal) a power steering pump resivour with 2 return lines to it. You don't need to replace the entire pump, just the plastic resivour. Then replace the vacuum booster with the hydroboost one. Buy new or otherwise supply and return line hoses. Thats about it. The other way is replace the power steering pump AFTER you remove that v-belt pulley or serpintine pulley. Now everybody knows that can be a real job if you don't have the proper puller. When its all done now you have superiour brakes and the vacuum now is for the cruise control or the air vent doors. Do more loosing a alternator belt and finding out too late that you don't have power brakes anymore... Been there... Have the pants in a bunch to show too....
Tech Articles. Always look.
Is there not an electric backup pump on those hydroboost units,
Is that type of backup available?
-----Robert
