05 No FICM Logic or Main power
Ford428CJ
FE Freak!
Klamath Falls, Oregon
Ok here it goes. I changed out a HPOP in this thing. Put it all back together. Now I lost Main and Logic power to the FICM. I checked the Fuses. Those seam to be fine.
I went to the FICM relay. Pin 1 and 5 have power (12.6v) all the time. Pin 2 I assume is a switched ground to trigger the relay!? I have nothing on Pin 2. The relay works as advertised and checked it. Any help would be appreciated ! Thanks
Dsl_Dog_Treat
Decatur,MI
Harness connectors seated properly?
Harness ground wire connected?
Iirc pins 1,2,3,22&26 are all internal grounds and shouldn't pop a code.
Ford428CJ
FE Freak!
Yes Sir. The harness is seated properly and I pulled it again to make sure no bent pins. And reseated again. The harness ground wire is connected in the back told the intake manifold.
Ford428CJ
FE Freak!
So I assume Pin 2 on the FICM relay goes to that?
Dsl_Dog_Treat
Decatur,MI
Here's the pinout for the ficm if you don't have it yet.
I'd say for shitzngiggles to unplug the fan clutch harness but no code popped for a fault.
Beginning to think your harness may be at fault since you have power in and out of the relay.
Ford428CJ
FE Freak!
I have the power at the relay. I used my snap on test light and checked all the grounds at the plug to the FICM. They are dead!
Thanks for the Diagram
Ford428CJ
FE Freak!
Well... Got a game plan..... The back grounding wire ties all those grounds together. I assume the junction of where they all meet would be at the base of the 3X plug. I’ll have to trace it and see where the break is at.
Sent from my iPhone using Tapatalk Pro
Ford428CJ
FE Freak!
Found the problems and fixed them! She runs
Ford428CJ
FE Freak!
Someone was tough on this ole 6.0. Lucky I have a over head creeper. And happen to look under the anti lock Break motor.... And noticed the cannon plug wasn’t seated....
REM70
