04 E350 - help with vacuum route pleeeease haha
Danielle
No, it's not finished
Dirty Jersey
Stuck on defrost. Smoking lines. Big leak coming from under the hvac fan housing area. I stuck my stick camera down there but still can't see it leak.
There is a black line that leads along bottom of wiper tray (top of firewall) to back behind the fan housing and down. On the camera I can see a check valve.
Where does that line connect to?
Can I install my own line and check valve? Need to know where this black line ends up.
The last photo. Is that a T-fitting? Is that small line supposed to attach to anything? That is where smoke pouting out of. Is it a vent and supposed to be open? Or is it the check valve has gone bad? I can't get my hands in there
I don't know where the vacuum line runs from this photo which is from behind the fan housing.
Sent from my VS835 using Tapatalk
Danielle
Dirty Jersey
Is this where that line supposed to go or is this the evaporator vent?
