Trying out my DTI timing unit
Brian VT
Maine, USA
The DTI seemed to be working fine again tonight.
And I finally got the timing to @ 9.5.
Once you mess with those ignition pump nuts a dozen or so times it's a piece of cake. ;-)
You don't even have to remove anything. Stubby open end wrench on the passenger side nut, ground down box end wrench on the driver's side nut, and regular open end on the top nut.
Soo....uhhhh..... vacationing in NW Florida anytime soon?
Really though, is it a crazy noticable difference?
Brian VT
Maine, USA
I didn't notice a difference while driving other than the type of smoke it's putting out the exhaust. (which is why I even bothered to check the timing)
I really don't have much seat time in this truck. Maybe someone that drives theirs daily would feel a difference after adjusting their timing.
If you're ever in Maine I'd be happy to check your engine's timing. :)
I have no business in Maine, but don't think I won't take you up on that if I do.
You are officially a pro!
Edit: I studied your picture more, I can see the metal loop under the "pezo" clamp. Sweet,
I'm pretty sure @IDIBRONCO is discribing a loop that you clamp a regular gas burner timing light spark plug clamp to.
Yes. That's the one.
kbenz
kannapolis, NC
I got mine on Ebay for under $200 and it has the transducer ring/clamp for the fuel line that Bronco mentions.
Here's a pic from one that's on Ebay now that I added an arrow pointing to the clamp.
That's the same one I just bought. $195 plus shipping and tax
77 F-250
New Hampshire
I used a pinch clamp to set the RPM and use a cheap gas timing light. I like the timing light method because I can use the buttons on the machine to get the timing amount.
Another issue I ran into with this unit on my buddy's boat was #1 had a bad injector. Moved to 2 and the reading was rock steady.
trythis
Commiskey IN
It really is "dynamic timing", there's so many factors : individual injectors popping, wear of the IP, fuel viscosity, etc. It ain't like timing a 302 for sure.
And the "dime thickness" is curious language to me, no one ever mentions quarters or nickels. And before there was electronic ignition in distributors think of how we splerged by sliding a whole dollar bill between the points..........if anyone can remember what "points" are.
Ohh yes I remember well we used a matchbook cover
94turbocrewcab-lb
Mid coast Maine
I’ve yet to time my truck. I’ll either make the trip to Poland and have brian time or or I’ll buy the kit. It’s a wash given the cost of fuel!
My truck definitely seems to have a bit more gray exhaust smoke vs black..i’m guessing it’d timing is off.
ntjapkes
