1994 E-350 Bakes Problem
Wildbill_81
Norfolk, VA
Hi all!
I just picked up a '94 E350 at auction. Got it running and the rear brakes were dragging and the front driver's caliper was stuck. I slacked up on the driver's side rear adjuster and thought the front brake hose was bad. I replaced both front brake hoses, steel lines, and freed up the driver's caliper. Now when I try to bleed the brakes I get no fluid from the master cylinder to the front brakes. I tried opening the bleeders and even loosened (and removed) the line from the master and still no fluid. Any ideas?
chickenpot
Central IL
Sounds like a bad master cylinder. Cheap enough to replace or you could take it apart and clean it up and see if the seals are good or it's gunked up
Alleycat
