phazertwo
Die Summer DIE!
I am in the process of pulling my tranny. I have lots of experience with smaller trucks (Tacomas are my specialty), and I have never had to worry about bracing the engine when pulling the tranny. The engine always just balanced, or leaned back just a tad into the fire wall.
So my first question is: Do I need to brace the engine in one direction or the other?
Q2: Should I remove the t-case or just get it all down in one shot? (I have a tranny jack that can handle the job, and it would save allot of time!)
Q3: Is it worth it to take the tranny tunnel off, and re-seal it when I am done, or just leave it on?
thanks guys for all the help!!
PZ
PZ
I usually install the side bolt first so the heavy starter has something holding it in place.... Please..... Make sure you disconnect both batteries before reaching up under the engine... You have around 1800 amps that will weld your wedding ring to you finger or burn a wrench in two... And guess what... Gravity sucks everything down in your face.... Melted metal bumps everywhere too... funny how it will burn the back of your neck....
