gonecrazyi
Well after fighting with the f350 I bought, it finally gave me the Dana 60 I wanted from it. The dang spring bolts rusted to the bushing guides and wouldnt come out, So I solved the problem and got a BIG Grinder. 20 minutes later everything was on the ground. Then I had to order a bushing kit, I think its from energy suspension. I had the choice between red or black, I had to go with red just to be different .
I think it took a total of 3 hours to totally remove the dana 50 axle, what a pain in the ass that was compared to the 60. To many things moved and twisted. I think it took another 3 hrs to prepare the 60 and bolt everything up. Everything went smooth up until we tried to remove the steering arm and the puller broke on the gearbox. So as it was getting dark we swapped the gearbox from the other truck and solved the problem for now.
I havent swapped the front driveshaft over yet, but almost everything else has been takin care of. The ride is 1000 times smoother, the steering is more responsive and the overall feeling of the truck is improved. One other thing that I have to do is swap the 4 in block over from the other truck, but as it sits now the truck is level.
Thursday's plan consists of putting the dana 50 under the f350 as well as replacing the bearings and swapping the outers from the dana 50 over to the 60. Can't wait to see what twists are thrown at me next!!
