BigRigTech
Diesel junky
My buddy's 97 F350 4x4 PSD won't start. He was driving it home and it pretty much quite when he turned into his driveway. The cam sensor was new this spring when I put a new IPR in it - I tried another CPS, no change. It is not reading any cranking speed on the tach. I tried another IDM that works good - no change. Fuse 22 for the fuel heater is ok as are all the fuses. I Don't have a spare PCM but I can get one on Monday. The check engine light cycles at key on. I did repair some corroded wires at the fuse box last spring for the PCM power, I will re-check my repairs to make sure it didn't fail. He said it worked A1 until he was just about home, then it started to run like crap before it quit.
It's obviously electrical, but where? I'm going to borrow my friends Snap-On scanner to check for codes tommorow.
....He's just as disgusted as I am....No more electronic diesels for this bird....IDI or a P-pump Cummins for my trucks only.
