i purchased the plate used for 400$
i did have to cut away at the tranny bell housing to get the cummins starter to bolt in there, if that helps you any if finding what plate i used. The guy named the company that made it and it was not a destroked or fordcummins company.
I used a 90 dodge flywheel that i machined and had a bearing pressed in it. I used a dodge pressure plate and a ford throw out bearing. now i ended up using the ford clutch disk ONLY because it still had some meet left on it. it is slightly smaller than the older dodge small splin disk is but it still has plenty of surface area to grab. The older style small spline Dodge clutch disk will bolt right in place once i decide to change it.
this pushed tranny and tcase back 2 1/4 inches. I shortended the driveline myself and had it balanced after..guy said it was the closest to straight he has ever seen for someone doing it on the garage floor.
. I just drilled new holes for the support and that was that. The 4x4 stick was just extended with a piece of 3/16 flat plate.
I did have to beat the fire wall in about an inch and a half maybe. I used ryno lining to cover everything for a nice textured look.
