redneckaggie
rebel w/o a cause
i finally got ahold of a turbo but have never seen one like it(though i have only seen one turbo idi) it uses the factory manifold on the drivers side and just has a crosspipe, and the turbo bolts to the passenger manifold, the downpipe seems like it would run towards the back of the engine then down which would be right because that is the only place with enough clearence to ge a downpipe through, then it has the turbo which has rajay and turbo engineering on it everything else is covered in the turbo engineering logo, it also has a box that was mounted on the firewall of the previous truck that has fittings for what looks to be the oil feed line. I'm in the process of trying to get pics on here but i lost my cord, but they will come because i will need to get some info on that box and some other things.
