Robt.Webster
My US Gear overdrive recently stopped shifting and is stuck in direct mode. After reading the many posts about this drive, I purchased a replacement set of switches and a shifting motor. I pulled the side plate today expecting to find a bad set of switches, only to find no switches at all. The motor leads were wired direct to the external terminals, although everything required to install and use the switches is there.
The box has been working with no problems. I am the original owner of tbe truck and had the overdrive installed by a reputable shop back in 1993. The truck is the one shown in my signature.
Has anyone seen this before? I have heard that US Gear sold some models that used current sensing in control boxes to stop the motor travel; is this one of them?
Since these control boxes are as rare as hen's teeth these days, I am thinking it might be better to install the switches and allow them to stop the motor travel. Would be a much simpler control scheme and may be more reliable in the long run.
Any thoughts on this?
Thanks for any feedback.
