any knowledgable propane people?- not IDI related.
hay guys, i have a Allis-Chalmers 4 cyl propane 3500k WH forklift.
lastnight she died on me!
definitely a propane problem.
yes, the tank has fuel.
she gets "all choked up".
ive traced it to a pressure release issue.
usually this valve can be pressed to purge the system.
lately while having this issue, it cannot be purged and will die.
im getting 12V to the solenoid, but i take it the solenoid is bad.
if i disconnect the propane line from the tank, and purge it through unconventional means, she will fire back up.
to only die again when i connect the tank back up and open the tank valve.
does anyone know the correct name for this part?
The FNG
NOT a Powerstroke!
Goldendale, WA
is it the solenoid on top of the impco regulator/vaporizer thingy? I have an impco propane system on my ford 351W, so I may be able to reference.
IDIBronco86
