1989 k1500 305 timing cover
woolfmaster
mars hill,nc
Hello,
I have a 1989 K1500 305 (150,000) and the timing chain is shot! Did the old Deg test it had more than the timing tag has Degs! I have done old 305 and 350 gm. Never a newer gm(last one 1978 305) . Is there a trick to taking off the timing cover? Don't want to replace the oil pan gasket.. the old covers you could cut a little metal and glue and RTV loosen some pan bolts and get the cover back on. (pray it did not leak!) I looked at a image 1988 GM 350 cover looks like the old ones same bottom seal setup?? but can't find a image of a 1989 305 cover. Any help would be great! Thanks! Tom
woolfmaster
mars hill,nc
Update: I looked at a oil pan gasket looks like the bottom timing cover seal is now part of the pan gasket? so it should stay when you take off the cover??
woolfmaster
mars hill,nc
Update:2 I got my timing chain set from Jegs today. I has the 3 key way's. 4+-0-4-. I tow a small RV (2500lbs) Has anyone did the 4 Deg advanced cam timing? I remember some OEM GM cams had 4 DEG advance for chain stretch to start with. so 4 more DEG (6-8 deg total advance) may ping! 89 gas.?? My brain says use 0 stock marks. I am ready to pull the timing cover tomorrow(friday).
Thanks...
IDIBronco86
Staff online
