Manual glow plug tech article?
wmoguy
Colorado
Pretty sure my glow plug relay is kaput. Thinking of going to a manual glow plug system while im working on it. Does anyone have a step by step tech article on doin this?
romulus
nor cal
i bet the electronic portion of the controller is OK, most likely the relay contacts are fragged. i put a new relay on my controller many years ago, and it is still working perfectly.
did you check the impedance on all your glow plugs?
IDIBronco86
