Voltage issues….. please help
firehonomichl
Worland Wyoming
Ok guys I just bought an 03 3500 automatic 4x4 crew cab 5.9 ****** it’s got 206,000 on it. Runs awesome however…. The check gauges light comes on and it start charging at almost 15v. The code it throws is battery temp sensor low circuit. And battery temp sensor low performance. I’ve replaced battery’s alternator battery temp sensor cleaned all the grounds and it’s still doing it…. Anyone have this problem?!
firfyter
US
On that setup is the voltage regulator inside the alternator or external. I suspect the voltage regulator.
mitsu tractor
