Dies and won't restart
94f450sd
somewhere,ma
Ok so this 05 duramax I'm dealing with will start and it'll run for a while on first start.
itll just shut right off like you turned it off.wont restart till it sits for a while.then it only runs a couple minutes before it dies it all over again.
I can pump the primer till my hand falls off,no start.let it sit and it'll start.i tried swapping filter head with the other truck we got(doesn't run so no idea if it's good or not)same damn thing.
I'm gonna put a motor in it but i need to be able to at least move it around the yard till then.
MadScientist
