Head gasket change????
Exekiel69
That depends on the shop rate per hour of work. Now are they re using the head bolts? Are they checking the head for straightness, leaks maybe check all the valves and guides and replace the seals while they are at it? Done right it will cost more than done quickly. Hope You get a good reliable shop.
ntjapkes
