Can I use WMO on my 2007 3500 Dodge diesel
Thor
Iceland
Hi Sirs
Can I use WMO 80% versus 20% diesel. I plan to either use cntrefuge or filter it down to 1 micron.
Are there any modifications that i need to do to my dodge to be able to run it ?
Rgrds
Thor
Thor
Iceland
Avarage heat is about 15 celcius summer, -5 celsius winter
I am not sure about the road tax in Iceland concerning burning WMO
subway
be nice to the admin :D
York PA
if you have a cat or DPF i dont think that would be a good idea. more of an emissions systems no-no like burning leaded gas in a modern gas engine. i could be wrong i have no direct experiance but i hate to see you burn up an expensive component trying to save money.
ameristar1
The One Blue Thing
Steger, Illinois
That 6.7 has piezo style injectors which are expensive and sensitive to fuel quality. You damage them, big $$$$$$$. Unfortunately, these new emission style diesels do not have the same fuel flexibility as the earlier diesels. I could be wrong, maybe somebody on here has run a 5.9 Common Rail on WMO or other fuel types without issue, but I know I wouldn't want to see you foot an expensive repair bill just to find out.
Desert Dually
cane corso
Southeastern Arizona
I have ;Sweet
not at a very high percentage, but i have successfully ran as much as 5 gallons of it mixed in with 30 gallons of diesel #2. No ill effects to report other than exhaust obviously smells different, but maybe not as bad as you might be imagining. Engine seems quieter and smoother sounding when it has WMO in the tank, but i have no way of "proving" this.
bobbywalter
mi
It can't be used in ANY amount without engine damage and increased emissions.
seen some of those 617 gobble up hyd oil and tranny fluid like it was candy.:dunno
thinking of putting one of the om617 in a truck for my daughter.
KFinn
Aurora, CO
So I am in the market for a newer dodge. Debating on the 05-07 5.9 or the 08/09 6.7L.
My uses or intentions for the truck are commuting and towing mix. I would like to run 50/50 WMO/Diesel like I do on my powersmoke. I also intend using a superchips programmer.
Which truck should I go with?
marblecrusher
Van Alstyne, TX
Stay away from the 6.7 if your running wmo all the emissions stuff added on will not take kindly to the wmo. As far as the 05-07 cummins most people will tell you not to do any more than 50%wmo and make sure it is filtered very well, through a 2 micron filter and centrifuged.
-Jordan-
idi traveler
Brashear, Texas
It is unlawful to run anything other than ulsd in anything made 2007 and later and 2011 and later in farm equipment in the USA. That is federal mandate.
yousave1
Co
I set out to buy something to run wmo and ignorantly bought a 6.7. After 3K dollars it worked. I've been running heated - centrifudged wmo, atf, and such and the truck loves it. If I could do it again I'd buy a 5.9 and not deal with the deletes.
yousave1
Co
I see your in aurora I'm there every now and again lets meet up. Buy a 5.9 cause of the emmisions that you'll have to deal with soon.
ntjapkes
